Mercury EFI Bigfoot 60 Dying Coming Off Throttle
This has been a pain for over 2 months now.
Engine runs and idles fine. However, if you give it throttle for even 5 seconds and let off, it will heavily bog down and usually die. This is what I've done and checked.
Cleaned injectors, replaced IAC, fuel pressure 42 pounds, new plugs, perfect compression, perfect leak down, manually checked ALL sensors and are up to spec, G3 system agrees with no codes, lower unit is great, temperature reads and runs as it should, throttle body pulled and inspected, fuel rail cleaned, idle runs at 650, bumped it to 750 and no change, running of auxillary tank with ZERO leaks, vaccume is good, neutral safety and ignition safety switch are good. What else is there??? It's driving me crazy so please someone help!
