Mercury Force outboard question
Duane98
I recently purchased 1998 Bayliner with a 120 hp Mercury Force outboard on it. It did not have a manuel and this being the first outboard I have owned I was wondering the correct fuel/oil mix ratio, and also does anyone know where I can get the proper manuel for it???? :)
studlymandingo
Re: Mercury Force outboard question
Welcome to iboats.
http://www.iboats.com/Force_Outboar...37029873--list_time.1176860461--view_id.55658
Use the above link for a manual.
does the motor run well now? The Force outboards are no longer manufactured and parts are hard to come by. You may want to get on the internet and find the weight of the boat, then drive to some scales and find the actual weight, there may be some waterlogging going on below deck. You should check the boat out thoroughly.​
roscoe
I would get a Clymer Force repair manual.
Fuel ratio is 50:1
16 ounces of oil per 6 gallons of gas
or 2.6 ounces of oil per gallon of gas
