mercury gauges ...
afphinfan
My wife bid and won a gauge cluster on EBay before asking me if they would work. They sound like a good deal except that they are for a twin engine Mercury. Gauges are Livorsi Gaffrig Mako Special Edition and include 2 tachs, 2 voltmeters, 2 water pressure, and a fuel gauge. Now I only need one of each, but I need them for a 60hp Johnson ... should I contact this seller and beg off? Or can they work? The whole deal was $57 shipped, but I would rather get what I need then get something useless for a good deal.
Thanks,
Mark
Scaaty
Re: mercury gauges ...
Gauges is gauges....use what ya need, Ebay the others and get some of your money back!
tashasdaddy
now thank your wife, you can always keep the others as spare.
afphinfan
Great, thats what I wanted to hear!!
Now for my next questions ...
Will any speedometer connect to the pitot tube I have or will I need to get a new pitot & tubing? Will all tachs be able to be set to my type of motor (Johnson 60 TJ60TLESM)? Lastly, I have a white tube that is connected inside the motor to the **** tube ... is that for water pressure or water temp? The only other gauges I would like are voltage, trim, and maybe fuel (when I get a sender).
Thanks again!
Mark
Silvertip
If the tachs should work fine. The tube you speak of is called a tell-tale and a water pressure gauge would be Tee'd into it. A water temperature gauge requires a matching sender which is any one of several types. One type screws into the head and is in contact with the water in the water jacket. Another type is a thermocouple style which mounts under one of the head bolts. A third style mounts on a bracket and sensor is in contact with the head.
