Hi again,<br />I haven't been on here for a while as have been so busy. I have a 1966 Mercury 650 65 hp that I have been doing things to get it back up to par. Mostly done except the distributor. Put in new points and condenser, but need to know if anyone can tell me what the gap should be set at. Also, the motor accidently got cranked over just a touch with the distributor off the motor. Will I have to realign everything to have the timing and stuff right? If so, can I just get #1 cyl. to top dead center of compression stroke and point rotor to #1 on dist cap? On the toothed shaft of dist that slips into motor there is one spot that is sort of flat like it will go in only one way, is this right? I can turn the dist shaft by hand and there seems to be a very good spark that bites my hand pretty good, so I think the dist is good. Also do any of you know about condensors, when they go bad, are they dead. I thought on a condenser, they are either good or bad, no inbetween like good till they are warm then act up, is this true? Better stop here, as I have dumped a lot of questions on you and may be a little overwhelming. Thanks, Marv.
