mercury inboard/outboard engines& outdrives
jonakel
Hello first time here We are looking to buy a '96 bayliner 2452 Express & would like to know the differences in the engines & outlegs the different Bayliners come with
One we are looking at has a remanufacturer engine 375hp (5.7L?) with an alpha one gen ll leg We have been told that the alpha legs fail when they have the V8 in front of them
I question the 375hp as well.The ones we have looked at in a 5.7L are 250-260hp am I wrong here ?
We are also being told if you go with the 5.7L a bravo ll leg is the better, more reliable one
could someone give us some good information before we put out the $$ & not be happy
thanks
Alumarine
Welcome.
The Alpha's are fine until you get over 300 hp I believe and then it's best to have a Bravo drive unless you're easy on the throttle.
You're right, 375hp is unlikely with the 5.7L. It's possible but I would avoid it. 260hp is with a 4bbl carb I think. EFI might be a bit more.
We'll see what the experts have to say.
superbenk
I believe the 5.7 can get 300hp with the MPI which I also believe is the manufacture's limit on the Alpha drive.
thanks
Ayuh,.... Welcome Aboard,..... Bayliner is known to put the smallest motors, 'n drives on their hulls to keep costs down,....
I too, doubt the 375hp claim,...
The Bravo II is a houseboat/ barge drive, a B1 or B3 would be a better choice,.....
The Alpha 1, Gen.II is happy up to 300hp, which is a pretty stout SBC,...
thumpar
To get 375hp out of a marine 5.7 would be hard. It is also to much for an alpha. My 5.7 efi is rated at 250hp with a bravo on it.
nola mike
The alphas are, in general, pretty reliable. Also, unlike the bravos, they're cheap and readily available should one fail. Are you sure it's a 5.7? Don't know if you might be looking at a 7.4...
