cpdinc1800
- Joined
- Apr 25, 2008
- 9
Hello All,
I have a 1978 M800 80HP 4 cylinder 2 stroke outboard that is running on three cylinders. The motor starts fine and idles for as long as I want it to. I removed the spark plug wires one at a time when the motor was running and the #1 cylinder makes no difference in the RPM, while the # 2, 3 or 4 will stall the motor if I remove them. There seems to be plenty of spark on the #1 cylinder, I grounded it to the block and it seems bright blue, not yellow. The plug will come out wet after running the motor, and the top carb looks like it was cleaned by the previous owner. I took it apart just to be sure all the passages were clear of debris and I found nothing, not even a little sludge. If I put the boat in the water, I can make 1 or 2 short full speed runs on plane, but I can tell it does not have the power it should. After those short runs, the motor dies and I have to start it again and it will idle as long as I want it to, but I cannot give it any gas in gear, only in neutral. It will rev in neutral but die in gear if I try to go faster than an idle. I swapped the coils and wires for the #1 and #2 cylinders and it made no difference. I even swapped the wires running from the switch pack to be sure the wiring was o.k.
On a side note/question, the motor is mounted to a 1996 KeyLargo 166CC center console. The cavitation plate is not even with the keel because the motor will not mount any lower on the transom. It is at least 3 inches higher than the keel. The transom has a stepped shape to it's profile, where the keel is about 6 inches in from the transom, almost like a jacking plate. Should I mount the cavitation plate even with the bottom of the transom or the bottom of the keel? It has no tilt trim control and I have been trying to change the tilt using the manual tilt pin, but as the motor barely runs my experiments have been useless. Turning the boat in anything but a WIDE turn causes the prop to lose grip, the motor bogs, and then I'm idling back to the dock.
Any insight would be appreciated. I have been working on this boat all summer, it was a damaged hull when I got it and I have rebuilt most of it and would like to use it before the season is over.
