ok, engine is a 1990 mercury m90 2stroke engine. its always had this "dead spot" since I've owned it.
I'm thinking I've found the two problems.
1. I believe the fuel filter is on backwards lol. the arrow is pointing towards the fuel pump outlet and NOT towards the carb inlet as you can see in my picture (yes, I had to draw the arrow as it showed up VERY LIGHT in the pic lol).
2. the carb linkage is all cracked up and "slips" against itself so not all three carbs are opening together exactly.
anyone know what the black part is specifically called so I can order replacements?? I need two of them, they are both cracked from people apparently over tightening them...
also, I'm assuming the fuel filter being on backwards isnt helping much either with fuel flow?
