lonestar65
- Joined
- Sep 24, 2019
- 18
I'm in the process of rebuilding a new to me 1985 Mariner SN 0A143401. It had not been ran for years when I got it, so I replaced the water pump and I was able to get it started. After about 30 seconds of full throttle I started getting exhaust out the tell tail. I started this project with the intention of replacing gaskets and now I have the complete power head tor down. I'm new to outboards, I've rebuilt several car engines but nothing 2 stroke. As you can see in the picture the cylinder walls are nice and smooth but the pistons and rings are ruined. What causes this type of failure? There is play in the rod bearings, could that be the cause of the damage? Can anyone direct me to a rebuild manual with proper torque specifications?
Lastly for those with years of experience on the Mariners is there any Sage like wisdom you can provide me with? Other trouble spots to watch out for - I know the crank shaft on these is subject to failure. Any parts I should replace even if they pass visual inspection? I was planning on buying all OEM parts from https://www.mercruiserparts.com/7-5-5206550-up but they don't offer a complete rebuild kit. Is there a OEM suppler that does?
Thank you,
Justin
Thank you,
Justin
