I have a 2001 Mercury OptiMaxx 200 will not run on the reload Will not rev higher than 2000 RPM check compression and all the cylinders that is good I have spark and all the cylinders the middle injector on the port side when I pull the wire there is no change in the way the motor runs all of their injectors wen pulled Or make a difference any help would be appreciated thank you in advance
