Mercury outboard flywheel removal.
tomdewitt
I have a 1993 Mercury 115 horsepower outboard that I am trying to remove the flywheel with a standard wheel puller not having much luck any suggestions short of getting the Mercury flywheel pulling tool?
BWR1953
Dunno about the wheel puller. 🤷‍♂️
I bought the Mercury wheel puller tool for about 20 bucks from Amazon. It was worth it right away. Works great. :cool:
Chris1956
The Mercury flywheel puller can be purchased as a combo puller and lifting eye. Very handy when pulling the powerhead.
I have never had to use it to pull the flywheel but have used it several times to pull the powerhead of my '93 V6.
BWR1953
Yup, I have mine on my parts motor right now. Convenient is definitely the word!
Chris1956
Gee, is that flywheel rusty enough? I would recommend you hose off the block and spray with corrosion guard stuff. It will protect the wiring as well as the painted and rusty surfaces.
It is a parts motor as stated.-----Those 3 cylinder 650 / and 3 cylinder 70 HP are not at the top of the hit parade.
