Mercury outboard stalls when run over 3500 RPM...HELP!!
climbAsky
The motor was just serviced. Was running great. I put in fresh gas, and, looking back, did not click in the fuel line to the fuel tank. I pushed it in, but do not remember hearing it click. The motor is now stalling, especially when run above 3500 rpm. I've clicked the fuel line back, but there may now be air in the system. Hoping for some advise on how to fix it. Thanks!!
What motor ??-----------Normally air is not an issue in a simple 2 stroke.
ondarvr
Not connecting it all the way would only be an issue "while" it was poorly connected, once fully plugged in the problem would be resolved, that is if the that was actually the problem.
climbAsky
It's a 2 stroke 90 HP motor. If air is not the problem, not sure what else it could be. Boat was running great till I put fresh gas in...what other causes would there be for the motor to falter and die out when run above 3500 rpm? When I'm running it, just before it dies out, the motor sounds like it's racing up, like a whoosh sound, and then dies. This also occasionally happens when I'm simply running it at low rpm, but not always. However, EVERY time I run it fast, it runs for 30 seconds to a minute, and then dies....I then have to engage the clutch, put the throttle all the way high without load, and then start the motor, and gently coax it up. Thanks again for your help and advise!! I've added some fuel additive also after this started happening, thinking it may be water in the tank, but I don't think that's it..but then, I really don't know much about these things....
The motor is running out of fuel.--Check the entire fuel system.-----Perhaps test run with another tank and hose.
