Mercury outboard trim and tilt
fastback4
I just installed a NEW tilt gauge and a New sending unit on my 1999 merc 60hp outboard. All parts where Mercury Parts. The installation was a snap but my gauge is reading opposite of what the engines position is. I 180'ed the sending unit but that did'nt help. Any suggestions out there?.Regards..Tom
fastback4
Re: Mercury outboard trim and tilt
rickdb1boat said:
Swap the wires on the sender...
Hi Rick..Swap which leads? I have a hot, a ground, and the sender ground.....Regards.Tom
fastback4
I forgot to mention i have a 1 wire sender that connects to the ground on the engine...Regards...Tom
rickdb1boat
Then the gauge is not compatable with the sender. This is the only thing that will cause it to work backwards...Call the dealer where you got them and explain what's going on...
