While the motor may have had a supplied prop the final size would depend on what the motor is on and typical activities.
I do believe the typical size would be "about" 11 or 12" pitch.But the actual size would depend on the application
If you don't have a prop tell us about your boat details,brand, year, size,dry weight, material,typical load.and activity.
The whole purpose of prop selection is to get the motor to operate within its wot(wide open throttle) rated rpm range.
If you have a prop the size should be near the base of the blades or under the prop nut.
