Hi All,<br /><br />Just in the process of fitting the modified Red Stator kit to my '88 80hp 3 Cylinder Merc.<br /><br />Instructions are a little confusing though, I have fitted the new stator, adaptor, voltage regulator, and rectifier. <br /><br />The instructions say to remove the red lead from engine harness that used to connect to the solenoid and that I should connect it to the terminal block as charging circuit connects direct to battery now???<br /><br />Any ideas where this red lead (has an inline fuse) should be connected? <br /><br />Thanks<br /><br />Crashed
