Mercury shift shaft repair
Dotong
Hi,
My shift shaft has broken at the top where it swivels on the white plastic plug.
The alloy that holds this plastic bit in place broke just enough for it to pop out, its like two rings one top and bottom and the plastic is in between, its the bottom ring that broke in half. it broke while i was taking the carbs off. if you unscrew the plastic bit off your left with a threaded arm. has anyone ever done a repair to this as i dont want to replace the whole shift shaft!
Thanks
