The Plug Manufacturers would have 2 different Plug numbers if there was a Recommended Conventional Plug.
It sounds like your engine is loading up and it is getting a dose of too much fuel on occasion. It happens in carbed 2 strokes all the time when they are Idled for any length of Time. If there is a Conventional type of Plug it might not make much difference as they too can misfire when the engine loads up. In the late 60s when the Surface Gap Plugs and CD Ignitions were introduced, they were supposed to make misfires obsolete regardless of the cause. They are a very cold Plug, but were supposed to be resistant to misfire from fouling because of the Ultra Quick High Voltage Spark, which was supposed to be Invincible.
Myself, I like the Surface Gap Plugs, the ones that came in my 1984 115, were still in it 14 yrs later when I traded it in, they had about 800 hrs on them, and inline sixes load up too when Idling for extended periods, but I was not one to run at below planing speeds for very long.
Your engine's Design of 2 carbs feeding 3 cylinders doesn't help Matters either. when it comes to optimum fuel delivery.
