mysticislandjack
- Joined
- May 31, 2007
- 12
Hi I currently have the frozen steering cable as was discussed in this forum. I followed oldman570 recommendations removing the nut from the cable that comes from the steering wheel. I can pull the small steering cable out to a point but i will not come out completely as if there is a flange that prevents it from coming out of the tilt tube. At the other end, I cannot budge the cable. I have used a considerable quantity of pb blaster, 3 in one, and some other penetrants, but most of what i spray just comes right out even when sprayed in the grease zerk. I applied heat to the area where the zerk is, (My motor is a 40hp 2002) on the side where the cable wont budge. I have a coupe questions:
Should the cable come completely out on the side where the steering wheel connects, and should i apply heat to the cable on the other side as apposed to the the housing? I appreciate all input, thanks.
