MERCURY SWITCH
LAERIC42
I AM TRYING TO FIND A PART # FOR A MERCURY SWITCHFOR A 1974 85 MERCURY OUTBOARD PART # IS NOT LISTED IN MANUAL. AND WHERE CAN I BUY ONE AT WHEN I GET THE PART NUMBER.
ronmold
Re: MERCURY SWITCH
Mercury switch is not really needed, it just kills motor if you tilt it up to far which pulls the water intakes dry. Save money, disconnect and keep the lower unit in the water when running.
phatmanmike
Re: MERCURY SWITCH
throw it away! no need. unless you have a habit of accidently starting your motor when its fully tilted in the " up " position. all its gonna do is die one day , and youll pull your hair out trying to figure why your motor has no spark... ...before you check the stupid blue mercury switch
rodbolt
Re: MERCURY SWITCH
the mercuy switch also shuts the motor down if you hit something and kick the motor out of the water. I would carefully test it and replace it. I try not to reengineer the motors I just fix them.I think I have only seen one that was actually bad in almost 30 years of practicing :)
LAERIC42
Re: MERCURY SWITCH
to the people who responded to my mercury switch problem many thanks.eric
DHPMARINE
Re: MERCURY SWITCH
Mercury mercury switch number is 58124a7,$40 bucks<br />But I don't thnk it will solve your problem.I've never seen one bad,and it is designed to ground the ignition and shut off the engine.<br />Has the position of the switch changed,so it keeps you from having spark?<br />DHP
