So I've been tinkering with my 1984 Mercury 115 hp since I still cant get it to start. I pulled off the Speed idle control like advised to do and have moved on. I was reading and some said stator some said other things but I saw something on another forum that said check the Mercury Switch. They also said disconnect the Mercury Switch and crank it. some said it would start right up , which meant there was a wiring issue with a simple fix if that worked. Can someone please help me on locating the "Mercury switch". I've searched for pictures with no luck. I got a diagram off the internet for my wiring and it sure does show a "mercury switch" come off the main wiring plug with a black and yellow wire.
