I need help please. I have a Mercury v6 serial # 5203765 with no spark. I will start from the beginning, but try not to make this too long. Went fishing last week outboard ran great, came in at the end of the day, beached the boat at the ramp and went and got the truck and trailer. When I tried to load the boat the outboard wouldn't start. Loaded the boat with the trolling motor and pulled it up on the parking lot. Opened the engine cover starboard side to see if there was anything obviously wrong, like broken wire or something. Didn't see anything obvious a friend of mine at the ramp at the same time asked what was wrong and I told him it wouldn't start. He said to try to start it and he'd try to see what was wrong I turned the key and it started first crank so i shut it off immediately. I backed it back down the ramp and in the water on the trailer I tried starting it again and again it started first turn let it run for a while shut it off, tried it several more times and no problem. Figured I had flooded it and brought it home. Went to fish a tournament the next day backed it into the water and it wouldn't start definitely no spark. Came home and started troubleshooting. I have now replaced the stator, trigger, switch boxes, rectifier, and eliminated the kill switch, and still no spark either side. I am open to suggestions, but also have a question would someone explain the relationship between the ign switch, kill switch, and ignition. I realize the outboard does not need power to the the ign to run but i also know that as is you have no spark with the ign switch off or the kill switch on is there a way to bypass the ign switch function for testing purposes?
