boatin-on-cherokee
- Joined
- Apr 14, 2008
- 37
This motor is on a 18 ft Skeeter and have enjoyed on water without any problems. I was on the water and on plane moving along very good when it just idle'd down and now will not plane out. Things I have done myself:
1. new plugs
2. had compression checked - said it was ok -
3. new fuel line and primer bulb
4. drained gas and replaced with new gas
5. new fuel lines
6. cleaned carbs - best I could with plenty of carb cleaner and a air hose
Also, the boat will start and idle with no problems.....can idle all day if I wanted too. The boat is an 85 model, not quite sure bout the motor, am assuming it is the same.
If anyone could please give me some advice on what I could have possibly missed would be greatly appreciated. And if any other info is needed, please ask and I will reply ASAP.
"Water temp is up-----need to be on the water"
1. new plugs
5. new fuel lines
