I bought this boat used about 5 years ago been running ok. So last year my motor started to act up. Hard start but good on higher r.p.m.'s 1000 r.p.m.'s and up was ok. So this year I did some tlc. New impeller, new voltage regulator, new spark plugs, new fuel pump, fuel filter and lines with primer bulb fresh gas new carb. gaskets. Cleaned carbs. but still have same problem. I took carbs. off and measured the floats. they where where off by about .100" so I set them to 9/16" per the manual and idle screws to 1 3/8 turn out per manual. Manual say's from 7/8 to 1 3/8 turn I took the kids skiing to the lake and it ran good for about 3 day's then same problem. Tried to adjust carbs. at lake and no change Now I am back to the same problem. I sprayed some carb. cleaner on the butterfly shafts and get the r.p.m. to jump just a little maybe 100 r.p.m.'s,. Spark plugs and spark looks good. I think someone put the wrong floats seats in the carbs. So the carbs. are going to cost me about $800, carb kit is going to cost me about $100 and if a coils are bad its about $400..
If my carbs. are bad why did it pull skiers for 3 day's and not miss a beat.
Question is am I missing something before I throw money at this thing?
Any input would be appreciated.
Thanks
Thanks
