Meri 170 removal ?'s
NPoulos
Anyone remove a motor from the boat / best way to get it all out I am gutting my boat to do a complete repurpose no more I/o its a bowrider now but I am making it into a v bottom jon basically why ? why not I alrerady have the boat and I don't have an out drive or money to get 1 plus I wanted a big v bottom jon so instead of selling my boat and buying another boat I will just make mine what I want so motor removal tips anyone ?20130806_115415 4winns.jpg
81 Checkmate
Re: Meri 170 removal ?'s
Pull the outdrive off...unbolt the motor mounts... undo wiring and plumbing........Then
Back that puppy up under a big-ol oak tree.........find a big stout branch...wrap your strap around the branch, hook up a come-a-long or chain fall and jerk the motor out.
Pull the boat out from under the motor...and procced to your refurbished the V-Bottom jon.
Btw...that gona be a heavy V-Bottom jon boat!
Good luck!
If your going to scrap the boat the engine is coming out of, try a chain saw and open it up. If you will save the boat, big tree as checkmate mentioned or a old swing set, not one of the new ones, they barely hold up an adult.
stonyloam
Make sure you part out that engine, lots of valuable stuff there:D;)
NPoulos
oh the Engine is def. up for part out as soon as I find a place to list it the boat is being converted to an outdrive bass boat already cut down the sides there is no outdrive but how do I get the part going through the transom out of there to patch it shut ? thanks for all the help
