Metal particles on drain plug
bj2455
Im wondering what a normal/acceptable amount of metal contamination is in the lower unit gearcase from a season of use. Got a 1989 Mercruiser Alpha 1 Gen1 coupled to a 5.7L Chevy engine. When I changed the lower unit gear lube for winter layover, there was a small amout of fine metal particles attached to the lower magnetic drain plug. I know those gears take a lot of abuse but anybody have an opinion on what is an acceptable level of wear? Gear lube was clean with no indication of water and the unit pressure tested fine.
Thanks....again
Bronc Rider
Re: Metal particles on drain plug
What color were the particles? If they were shiny metal ones, its bad. If they were black, not so bad.
bj2455
They were dark colored.....definately noy metal shavings. What is the dark metalic substance then?
z284u2try
If it was the consistency of metal dust I would not worry.
Don S
Normal wear. That's partially why the magnet is there, to keep the metalic grit out of the oil as much as possible.
