MFG 1969 Edinboro Transon Drain and Hull Cleaning Questions
Merrimanr
I have had by 1969 Edinboro for 6 years now and all is very well. I still have a couple of questions that I am still stumped by.
1) Because I still have yet to procure a good cover that is rain proof, I still have to bail water. I simply connect a pump to a hose that I feel through a small hole in a "pocket" at the stern of the deck and pump water from the hull space below. My question is: How was the orginial design supposed to work? There is a drain plug at the rear of the pocket depression in the deck, but I am curious how this was suppose to work.
2) I am also looking for suggestions on how to best clean the accumulated scale from the hull. This boat is stays in a Michigan fresh water lake, but I can get the scale of traditional cleaners and elbow grease. I got the boat from a young man in Cleveland who had the boat in mint condition and I am trying my best to keep it so.
Re: MFG 1969 Edinboro Transon Drain and Hull Cleaning Questions
Ayuh,.... Welcome Aboard,....
On the wagon, the bow is held High, 'n the plug Out, makin' it self drainin'....
At the dock, a bilge pump is installed in the pocket, so's water can be pumped out....
Or,...
Ya go for a boat ride, 'n pull the plug, once over displacement speeds... It'll drain itself...
sphelps
Welcome Merrimanr !
First off is you sure have one sweet looking Edinboro !:cool:If it's like mine you have a drain for the the above deck area and second drain for the below deck area. If you keep stored in the water you don't have a choice but to bail or pump out water. I guess you can install a pump with a float switch. But would still need to check on it from time to time. Some pics would be helpful
You should post on the MFG forum . The guys over there might like seeing some pics of her..
