MFG Westfield - Latest addition to the fleet!
mfgniagara
Somehow I've managed to add a fifth boat to the fleet here today.
A buddy called me early this morning and asked me how is the best way to cut up an old boat, when I asked what or why he wanted to cut up a boat he says he bought an old boat for it's motor and trailer and needs it gone. My first reply was to just take it to the dump, but he's too cheap to pay the dump fee.
I finally asked what kind of boat it was and what was wrong with it that he wanted to cut it up? He went on to say its an old MFG which needed new seats, and its too narrow. When I asked him how long, he said I'd have to come over and measure it, he's already put it down in the woods.
When I got there I found a super nice 1967 MFG Westfield, still on the trailer with an older 60hp Johnson on it. The deck is mint, the hull doesn't have a scratch. The transom is rock solid and my 300lbs on the lower unit doesn't budge the transom. There's a Bimini top, the original steering still works and the gel coat has almost no fade at all. Whoever removed the seats filled the deck holes with 5200 over rubber plugs.
Needless to say I promptly offered to dispose of it properly.
He handed me the title and said to bring back the trailer.
A closer look at the boat at home revealed an even nicer boat, most of the finish issues were just dust and dirt, the transom had a pair of old fish finder transducers screwed to it, so I removed those, drill tested the holes and got dry wood, so I promptly filled the holes with Marine Tex epoxy and the screw holes are gone. I pulled the motor, slid the boat onto a newer roller trailer and returned those right away. The motor has an adapter plate behind it, about 1/2" thick at the top, and 1/8" thick at the bottom, and it's curved on the front side to match the transom. The transom bolts are stainless and in good shape, so I plan to hang a later model 50hp on the boat soon.
If I hadn't gone right over, chances are he'd have started cutting it up. He had it parked next to his excavator and he had a chainsaw gassed up and ready to go when I got there. He was planning on cutting it up and putting it 6' under. I've got the title in hand and the boat was being used and had a current registration in the side tray.
The dash has no holes drilled at all other than three that appear to have been from an old fish finder. There's an old Ray Jeff depth sounder as well.
I have to decide on what type of seats I want to use, most likely a set of back to back seats are in order. The boat will clean up to look almost new when I'm done. Even the windshield has no scratches or cracks.
Does anyone have any pics of a 67 Westfield dash layout? This one has no gauges at all, just a black block off plate covering four 1" holes. I want to add a tach and speedo and would like to make it look factory if possible. I have a new pair of vintage Airguide gauges. I'm thinking maybe of putting the bilge and light switches all on that black panel, and having the speedo and tach on the next level above that? That leaves room for my fish finder and GPS to be mounted on top. I also want a good compass in plain view somewhere right in front of me.
woosterken
Re: MFG Westfield - Latest addition to the fleet!
WOW!! what a score :)
have you looked atfiberglassics ?
woosterken
mr 88
My 67 came with two panels 4"x7&3/4" one located where yours is and one directly above it on the next angled part of the dashboard. The lower panel had a factory 2"hole drilled behind it. Someone installed the light and horn controls next to the panel,duh.That is all I have on the dash.I think the selling dealer installs the gauges and ignition as they are different with Merc and Johnrude.Mercs key is on the throttle controls.So install them anyway you feel looks stock.I have noticed that the brochure and what is out there do not always jive.Actually in the brochure there are no gauges shown on the dash,it is blank. You have the Skiff style windshield which came on the Regal model that only came in gold . Mine has the vent with the curved window. The ski rack and storage compartment listed as standard equip and shown on both pictures from 67 is not on my boat, I have a bow rail that is also not listed and it appears stock.You have the white panel stripe down the center of the deck, not listed in the brochure.I am glad you saved it from Mr.Stihl and what a find she is! If i had a "buddy" like that a case of finely brewed malts would be on his doorseps.
pduquette
Ensign
Wow! what a deal !! sweet looking setup !! Welcome aboard too , your only membership dues are more pictures ! lol !
You should have your friend give YOU the beer - for disposing of that boat and saving him all that time and itchy figerglass !! You did all the work - right?!? Keep us posted . peter
mfgniagara
I spent Sunday swapping it onto a newer roller trailer, I'm amazed at how clean the underside and keel are. Usually these things have a few scars at this age. I was hoping for a somewhat warm day but I doubt if that'll happen this late in the year. It needs a good soap and water wash before I get to work on it. I ordered some well nuts for the seats, I have a pair of brand new light gray back to back seats that should work find in this boat. Somehow I don't figure that pedestal seats would be a good idea on the all glass deck, at least not with a guy my size.
The transom being solid is what surprise me, it's the first 60's era MFG I've seen with a good transom. Even my Niagara and Edinboro needed new transom wood.
A bow rail would be nice but I'm not going to sweat that very much. Not having one makes it easier to toss the anchor out and to tie up, but bow rails make good cargo rails to contain things stowed on the bow while fishing.
On my Edinboro, I mounted two cleats on each side which hold my cooler while we're fishing. It's out of the way and easy to get to when a fish is caught, it also puts the weight up front while I fish off the stern.
I was glad to see it's got those ski lockers, they make great tackle compartments. I never saw a purpose for them or thought twice about those things till I fished a boat that didn't have any storage.
Once I give it a good scrubbing, I'll get some more pics of it. The next stop for now is into the garage to get a motor and controls. I do want to add a tach and a good fish finder. Plus a VHF radio and GPS.
Something that surprised me is that it sits lower on the new roller trailer than it did on the old flat framed bunk trailer with 8" wheels. It should be a breeze to launch and load.
a70eliminator
I have a 67 Westfield Regal that looks exactly like that in the same color too, here's a pic of the original instuments, I did add the bow enclosure and upgraded the steering. search MFG bow storage mod. pics. and you can see a bigger photo of the dash, I don't know how to attach the link.
mr 88
Is that a bilge pump hanging on your transom ? I take it that is for a livewell if it is.I had a boat that had thru hull ftgs with some ball valves which worked fine when trolling.I had a auto bilge pump mounted near the top of the well which kept her fresh.The only prob was when on plane it would drain it all out. Probably should of put one way valves in somehow.
a70eliminator
Yep, it's just tie wrapped to the transducer mount and the hose is tie wrapped to the ski eye, it pumps into my portable livewell that overflows into the spalshwell, We've also used it as a washdown after my wife or daughter "squats" in the splashwell. It's just a portable set up that can be removed in a couple seconds. The power feed wires are attached to the hose with heat shrink tubing and aligator clips on the ends.
mfgniagara
Got any better pics of your interior? Is that a panel that closes off the under dash area?
We're finally getting some decent weather here so I can spend some time getting mine ready to use. There's a few odds and ends that need doing but nothing big. Mostly just mounting the seats and hanging a motor. I do still have to decide on which motor to use, either a 55hp twin or 65 triple Evinrude are my choices. While I lean towards the 55hp for it's lesser weight, the 65hp is also ready to run. I'm also debating whether to convert to a teleflex steering or just leave it the way it is with its original pulley and cable steering. What's there works, it's just a matter of making it a bit more modern. Leaving what is there is simpler and it don't look like it's in bad condition.
bgefcdha
I have a Westfield but it not as good a shape as your I'm getting ready to put some time in it and need to identify what it is and find some pictures of what it was like new. I have a 65 hp Evenrude sport four, electric start. I think it just needs an head gasket and some TLC I need to mount some used seats my cousin recycled from a boat yard he works at. most of the steering needs tobe installed and lights, battery, bilge pump sound ect,ect. all I see on it's name plate is an serial number how do it find it's year?
mr 88
Go to fiberglassics.com then to there library.They have a pretty complete listing of MFG's.Look for the interior colors listed and pics of the hardware.You should be able to ID the year from that.Sometimes the trailer and motor are the same year,what does the regs say? for the trailer? Motor should also have ID and serial number and that can be crossed referenced on this site under Johnson/Evinrude sticky post.
