MFS 4,5,6 B conversion kits PARTS
pvanv
Re: MFS 4,5,6 B conversion kits PARTS
See figure 14 in the Factory parts catalog. The MFS4/5/6 is not capable of electric start. RC for shift and throttle only. Likewise there isn't a provision for a steering drag link rod; If wanting wheel steering, you would setup a system to use hook plate attachment to the motor. The SRC kit has about 40 bits and pieces, and is as follows: 3AS838800M SRC FITTING PARTS ASSY $107.97, and does not include the morse cables or control box. Installing the kit deletes the tiller handle, and the throttle cable is alongside the shift cable. The shift connects to the original shift handle, and the throttle connects to a bellcrank and shaft assembly that exits the stbd side of the lower cowling.
