Michigan SMC 43 Prop
RSchendel
I have a '58 Evinrude 18hp. I can look up the recommended props, but my dilemma is that the current prop is marked Michigan SMC 43. I can not find a reference that tells me the diameter and pitch that I can compare with the published recommendations.
Where can I find the specs on a Michigan SMC 43 prop?
steelespike
Re: Michigan SMC 43 Prop
A prop shop can measure it for you. If it needs a repair thay can do it.
58 Evinrude catalog indicates 9 1/4 X 11.Don't worry about the diameter as long as the prop is indicated for your motor.If your boats that which a 18 would be expected to push the standard prop should work.
