Hello folks (new to the forum), I have recently purchased a mid 70's 20 hp mercury outboard. It runs, starts, idles, fine. I found a cracked fitting that was leaking gas and I had the fellow replace a few fittings and lines and at that time I was told that if the primer bulb is over pressurised the gas would flow out of the carb, and indeed it does. My issue is that with the gas line connected and the vent closed on the tank, there is a build up of pressure enough to push the gas out of the carb and into the boat/Lake.
Not being mechanical I was hoping to get some advice weather this is to be expected or what the problem might be so I can have the issue repaired.
Regards
Ron
Regards
Ron
