droptine77
- Joined
- Nov 17, 2007
- 12
Over the past two days I have looked at two differant mid 70s 70hp johnson motors. I check out the compression on both and they both averaged around 60 psi. Now this was with the engine barely turning over on one and me spinning the prop to turn the motor over on the other(bad starter). Not sure if it makes a differance or not. What should the compression be? Any help would be appreciated.
