I have a mid 80's Johnson 140hp that has a misfire at idle. It runs out fine but runs poorly when idling. Just rebuilt the carbs due to water being in the fuel tank. Using a small portable tank with all fresh fuel now. Did compression test all good around 125psi. Plugs look fairly new. Also has 1 new coil. I'm thinking either another coil going bad or module. How do I test foe a bad coil? and how do i tell if the module is going bad?
