midsection
jason1150
72 mercury 1150, keep having to tighten the midsection nut, is there some trick to keeping this thing tight, thanks, Jason
Laddies
Banned
Re: midsection
I think your talking about the nut on the swivel pin, if that's the case usually the bottom yoke is worn out. To change if requires removing the shift shaft and I know a couple that were repaired by a good clean up and thickened epoxy in the spines on the nut. Certainly not the best repair but I hear it worked.
jason1150
Re: midsection
sounds like that should work, I'll give it a try, thanks, Jason
