I have a 1980 Mercury 6 cylinder outboard motor that has had a slightly milky color to the lower unit oil when it's changed each year. It isn't significant and that's why I haven't done anything about it.
I was replacing the impleller on this motor and while I had it apart I blew on the end of a small plastic hose that comes out of the lower unit and attached to a line coming from the back of the motor. When I did this, I noticed that a small amount of air was coming from a chip/crack in the front of the lower unit housing. It's not near the bottom where the gears are but is about half way up the unit. I'm wondering if this is where the water is getting into the oil? There isn't any oil that leaks from this crack however.
Can someone help me understand this and if I should get it repaired. Also what function does this plastic tube perform. Should I be able to blow air through it normally?
Thanks for you help!
