Milky Engine Oil
NoExcuses
Hello, I'm looking for help to determine how water is entering engine, I've replaced the head, riser, exhaust manifold and air intake gaskets last fall but when I dropped the boat in this spring and ran it, I still have water in the oil. What are the steps for determining where water is intruding?
Engine is a Volvo Penta 5.0 GXi-E with 700 hours.
Ayuh,.... Drain the coolin' system, isolate the block, 'n pressurize to 'bout 15 psi, 'n Listen,.....
I'd guess a cracked block,...
