stevenhickeys
- Joined
- Aug 1, 2012
- 53
Hello,
I picked up a 74' Starcraft American 20 with a Mercruiser 165 with I believe a type I out-drive. The motor runs sweet and the O/D shifts with out any problem.
I drained the L/U fluid last night and discovered it had some water in it and it was very milky.:facepalm: The previous owner said the boat has not been in the water for @ 7 years.
I would assume the seals need the be changed in the L/U.
My question is:
#1 is this a job I could do myself or should I take it to a shop?
#2 Should I remove the L/U for the winter or should I fill it with fresh oil and tackle the job in the spring?
#3 Other than the L/U, is there any other areas that water can leak into the unit to contaminate the oil?
Thanks in advance for any help.
SH
My question is:
SH
