was going to change out impeller went to drain my oil and its all milky white.
anyone suggest a common cause for water getting in the housing? Ive read the drain plugs could leak mine seem good. also read to put some air in the housing and see if you can track down leak. Also what is the proper way to set lean rich fuel. Im waiting on my repair manual just moving faster then it gets here thanks appreciate all the help Ive got on here
