Frank Acampora
- Joined
- Jan 19, 2007
- 12,004
For those who are wondering if their lower unit oil is contaminated with water, I submit these photos. This occurred with only about five minutes run time. I was water testing an engine I had sold and mounted on a boat. It did not perform satisfactory so I brought it back to the garage. There I observed white oil dripping from the water intakes.
The lower unit is a dual exhaust, 2 piece drive shaft, off a 1990 90 HP Force. Upon removing the water pump and bottom plate, I discovered that the top seal had failed AND the lower seal had worked out of the plate, sealing absolutely nothing. Two new seals and a bit of Permatex to lock them in place solved the problem.
