Ok, here goes nothing.
Bear with me for a relatively long story, I need help.
Bought my boat 2 seasons ago, went through all of last season (~100hr) periodically checking my drive oil, no loss of oil, no evidence of milk at all.
Beginning of this season I decided it would be a good idea to change the drive oil (it was pretty black but didn't feel like it had lost its oily properties.)
Well, in the process I ran into the infamous inner prop stuck on the shaft. Had to cut the props off in order to get to the drain plug to change the oil. What a headache. Either way cut the prop off, changed the oil, put on new props and went fishing.
First trip was about 50 miles, got home check the drive oil, and it was milky. Did a pressure test and was able to easily find that my shaft seals were leaking. Looks like i nicked the outside of one with the sawzall while removing the props. Replace all 4 shaft seals and pressure tested again, no bubbles. Flushed to drive twice with clean oil to get any water out, put new oil in and went fishing.
Another 50 miles later I check the oil AND ITS MILKY AGAIN!! I think maybe I did the seals wrong and pressure test them again, no leak no bubbles.
The drive just sat overnight pressurized to 8psi and it didn't budge!
It also holds vacuum.
I DONT KNOW WHAT TO DO NEXT, PLEASE HELP!
A few notes:
I initially thought this was related to removing the seals but is there a chance keeping the drive on the motor over the winter may have caused a leave else where.
Could I have damaged a seal or oring while hitting the props with a hammer to get them off?
What pressure and how long are you supposed to pressure,vacuum test, cant find it in the book?
A few notes:
