Scott06
- Joined
- Apr 20, 2014
- 7,648
if you look at the way a lot of gauges are wired the ignition on voltage from the key is often daisy chained through the gauges, a lot of exposed terminals to get loose and corroded. As lou said that can be a lot of work to run down but connections are the key. Could be in the cannon plug too if you have 14.3 on the engine/battThanks. I noticed that too. Shows 14.3 on the battery and same on back of alternator. My boat does that also. Not sure why. Faulty gauge maybe?
Ken
