79Glastron
- Joined
- Jul 18, 2007
- 256
My neighbour knows I work on boat motors (Mercury) and he asked me to look at a 1969 Evinrude 9.5 that his father in law owns. He said it would run for a few seconds then stop. He had some shade tree look at it. They replaced the points and condenser (incorrectly gapped) and new plugs. They said the compression was low and wanted to pull the head, he said hold the phone and wanted to get a second opinion. I gaped the points put fresh gas in the tank and attempted to start it, no luck. I sprayed some gas mix down the carb. It fired and ran for a few seconds and stopped. I checked the compression and spun it over with my drill, I got 85 dry and 95 wet. My Mercury's have around 130-160 depending on the motor. I think this motor is worn and cannot run correctly with this low of compression. What do you experts think? I don't think a carb cleaning will correct this one, it will not run on its own at all.
Thanks!
Thanks!
