I just purchased a used (i believe 2004 model) 65 lb thrust, 60" shaft, 24V Powerdrive with Autopilot, Copilot, and Universal Sonar. Two Problems:
First, it vibrates VERY bad during most speeds. If i point the motor straight, turn the speed to say "6" or so, it vibrates acceptably but still rough. Then as I turn the motor to the left or right it goes nuts. Could a bent shaft cause this? Because the head tilts when its turned left or right like a bent shaft would. This is installed on a 1650 Fish Hawk.
Second, When I tried AP the first time it didnt work. THe water was glass, no wind or anything. I got the boat going straight and pressed the AP button. The motor went nuts and swung all the way left and the all the way right, so I shut it off. I waited a while and tried it again, this time it kept turning left and tried to do a complete circle. THe batteries were fully charged. When I got home I tried it out of the water to show the neighbor, but when I pressed the button it didnt go nuts. Any ideas?
Thanks!
Thanks!
