MINN KOTA THRUST VS HORESPOWER
stingerstang
I was wanting to find out on the trolling motors, what the thrust is in horsepower...for example, if I have a 34 thrust troller, how many horsepower is that? If anyone knows how to figure that out I would appreciate the help...Thanks in advance!
Luna Sea
Re: MINN KOTA THRUST VS HORESPOWER
From MinnKota's site:<br /><br />Electric motor power ratings are in pounds of thrust. How do I determine the thrust requirements for my boat?<br /><br />Thrust requirements are determined by the size and weight of your boat. Refer to Select A Motor in the producta section. This guide is established under normal lake fishing conditions. If you frequently fish in heavy winds, rivers, or adverse weather conditions, you may want to consider a higher thrust electric motor. It’s always better to have too much power than not enough!<br /><br />What is thrust?<br /><br />Thrust is a static measurement in pounds of our motors pushing or pulling power. <br />Minn Kota's published thrust ratings are laboratory measurements taken by using a load cell and with voltage equivalent to a fully charged battery (or batteries) applied directly at the motor brushes. <br />How does thrust compare to horsepower?<br /><br />Horsepower is a measurement of "work" being performed. <br />One horsepower is a unit of measurement equal to 550 foot pounds of "work" per second. <br />There is no direct correlation of thrust to horsepower. Contrary to what you may have been told, fifteen pounds of thrust DOES NOT equal one horsepower. <br />As noted in the previous definition thrust is simply a static measurement of force. <br />How does thrust compare to speed?<br /><br />"My buddy has a 36 lb. thrust motor, we have the same size boat, yet his motor moves his boat just as fast as my 42 pound thrust unit. Why is this?" <br />Again, thrust is simply a static measurement of pushing or pulling power, and higher thrust does not necessarily mean greater speed. <br />Speed is a factor of prop pitch and motor R.P.M. <br />Given motor R.P.M. under load, and Minn Kota's 4" prop pitch, the approximate speed that a motor will push/pull a small boat can be calculated. <br />The formula for this is <br /> .85 (4x) x 60 = Miles Per Hour<br /> 12 5280 (Motor RPM = X) <br /> <br /><br />How do I convert thrust into horsepower?<br /><br />Many people think that the more pounds of thrust they are getting, the faster the boat will go. This is not exactly true. With trolling motors and outboard motors, boat speed (and acceleration) depends on horsepower and prop pitch. By changing prop pitch, you can trade acceleration for top speed. Our trolling motors have props designed for maximum acceleration. When you hit the power, the boat responds immediately. This also allows you to hold the boat in high wind conditions. Top speed with our motors and props is about 5mph. Small boats will reach this speed with most of our motors. Larger boats require our largest motors to approach this speed. Comparing our motors to gasoline outboards is difficult because most outboard props are designed for much higher speed.
