minn kota trolling motor prop
r8rfan
I just bought an older bass boat. Is an 1982 bass tracker. Has the original minn kota 565 trolling motor on it. My question is does anyone know where a person can get a prop for one that old and that style? Is held on with a kotter pin of all things.<br />Any info would be greatly appreciated.<br />Thanks a lot.
OBJ
Re: minn kota trolling motor prop
Hi r8rfan. <br /><br />Props for these minn kota's are still available. Might check in i-boats store. May be there. If you have taken the prop off, you will notice a drive pin inside. The cotter key just retains the prop to the shaft. Works. No problem.
OBJ
Just looked at i-boats store.<br /><br />What you need is a MKP-6 prop. #2061125. $17.54.<br />Take a look. ;) ;)
r8rfan
OBJ<br /> Thanks for the fast response and the info. I shall check it out!!<br /> I haven't taken the prop off. Is still in good shape, but I thought it kind of strange to have a kotter pin! Makes sense though,now that you explained it!<br /> I believe I'll order a spare just in case.Not like being able to go to Wal-Mart and pick one up on short notice!<br /> Thanks again.
