ben2go
- Joined
- Jul 29, 2008
- 411
I have a 1990/91 3HP Minn Kota trolling motor.The prop pin has rusted into the prop shaft.I let it set and used pentrating oil everyday for 2 months.I have tried squeezing it out with channel lock pliers,pressing it out with a C clamp,and hammering it out.No dice.I also have 2 wire ends in the copper armature wiring that are buried in the copper windings.These look to be factory cut.No chafe or burning.Are the ends supposed to be that way?I wouldn't worry about it but I need to save the case and the armature if possible.The threads on the prop end of the armature are bad,and I may need to replace the armature.Anyone know the thread pitch and size?Maybe I can run a die over the threads to clean them up.
