This past weekend I was out using my trolling motor and it started acting up. It is a Power Drive 55 with the add-on Ipilot. What it would do is:
Work great for 20 to 30 minutes while using the autopilot advanced setting along with cruise control, then it would loose teh satalite signal and the display on the controler would only show the spinning prop and speed setting. When I would turn off the controler and restart it, it would show sat signal like it should but right after I start the motor and pick a navigation option it would drop the sat signal and just show the spinning prop and speed setting. I would switch to a different battery and it would start all over again with working great for 20-30 minutes and then the spinning prop issue. When we got back to the shop we tested both batteries with a load tester and both where in the green for volts and under load.
could the electrical motor act this way just before goes bad?
Thanks
Thanks
