mirrors and t molding where to get them
michaelrj9
where do you purchase new mirrors or how do you make them?
(plexiglass with the reflective coating) been looking all over with no sucess
Also been looking for the t molding that goes around wood cutouts etc... looked at the hardware stores and couple of boating stores around me with no sucess
Thanks
Michael
tashasdaddy
Re: mirrors and t molding where to get them
t mold try jamestown distributers, what type of mirror are you looking for? rear view or a bulk head mount in the head
michaelrj9
I looked at jamestown distributers for the t molding. I don't see any there
The mirrors I am looking for are for in the head.
(plexi-glass mirrors)
Thanks again
Michael
tashasdaddy
you may have to call the local mirror and glass company. they will know of something you can use, for better view i would consider using safety plate glass mirror just thought of something have you tried travel trailer supplier.
tashasdaddy
googled plexiglass mirror and came up with many on line suppliers. give it a try. on the t molding what are you trying to do, just finish off the edge or cover a joint. have you thought about the edging that is heat activated and you use an iron to apply it. it comes in many colors or unfinished.
michaelrj9
Thanks for your help.
The mirrors I ended up getting at a local glass company.
The T molding is what is used on my boat around the edges of cabinet where the mirrors are at in the head.
I bought some of the wood veneer that is heat activated glue I could not get it to stick in the rounded corners that good.Maybe I will try to use different glue in the corners maybe then it would stick better.
Thanks for all your help.
Michael
