Mis behavin' 85 hp
Aggitated
Hello, I have a 88, 85 hp that is misfiring. The motor has great compression, 145 lbs on all three cyl. The fuel system has been gone through, carbs cleaned, new fuel lines, reeds checked, fuel delivery looks good. The stator was replaced. Motor skips (coughs) when placed under a load. It idles great, runs low end great, but soon as I give any gas it starts missing. Any Ideas?
jerryjerry05
Re: Mis behavin' 85 hp
Top of the Force forum.There is a post by FrankA called a linc and sinc.Do this then.
Check gas for water.
Check float levels.Clean recirculation system.
Check the linkage for broken connectors???
