long story try to make short, vro failed. temp sensors limited the engine to about 2200 rpm. stopped engine. replaced vro and engine starts.idles. misfiring just above idle as it tries to plan out,then starts to stall.pulled plugs shecked compression. 1 cyl not firing plug was like new conditon. checked coil with meter ok, did spark test on coil will arc about 1/2".<br />carbs were rebuilt and fuel system replaced at same time as pump. enough background, does it sound like head gasket. compression was 95psi in that cyl compared to 110-115 in others. sorry for the detail, seems to help in long run<br />thanks for help in past
