Hi all, I put the boat in the water for the first time yesterday and I have what I believe/hope is a small problem. The boat turned over and started right up (which already was more then I expected) we ran it for about 5-7 minutes at various speeds with no issues. After we stopped and ate for about 30 minutes I restarted it and when I started to throttle up I now have a miss/backfire. But heres my kicker. it only happens at 2000-2500 rpm and at wide open throttle (4500 rpm) when I ran between 3000 - 3500 RPM no issues. I bought this boat used and Im assuming (based on the old trailer registration) that it wasnt ran last summer. when I got it, it had 1/4 tank of presumably 2 year old gas in it. I only added about another 1/2 tank to it. Could the old gas be causing my issues? I plan on filling it up with premium the rest of the way and adding to some carb cleaner to the tank. If that does not fix it issue Im thinking new plugs and wires. Am I on the right track with this or am I thinking to small and this could be a bigger issue?
also WOT was 4500 rpm. does this sound right for a 1996 5.7 Merc pushing a 21ft boat?
thanks
thanks
