Re: Missing ID Plate on 20' Lund Alaskan
I think the only thing that might be original would be the vinyl flooring as it's the hull only he got..
One thing I wanted to share is something that happened to me last fall as I had my ol completely restored65' Starcraft Jupiter with an 05 Honda 50 into one of the local marinas. I was chatting with their long time and well respected mechanic about cavitation plate heights, props etc etc and he asked me if I'd ever had a leading edge sharpened on any of my props which I replied "no" ....he mentioned all the guys down on the lake that run the offshore boats have him work their props because it works for them.....before I knew it he had the Michigan SS fan off and back to his hobby belt sander and as I watched him methodically rotate each blade to sharpened the leading edge on the one side of each blade only...after reinstalling it, he sent me on my way, he asked me to let him know how it worked for me...once I launched it and got out onto the bay, I thought about how before that prop would ball weeds up so bad I'd have to lterally cut them off the hub to get it cleaned off...something as simple as doing what he did has eliminated that now as I intentionally was messing around in the weed bed trying to get it to plug up which it did not do..I called him to thank him...I actaully think because it enters the water easier than I might have picked up a slight bit of top end but which isn't a big deal to me but I was so impressed I will never install any prop on any boat without first putting an edge on each blade first....just need to figure out a way to check for balance though...my 2 cents
Thank you..
